Originally Posted by qiksix
Yeh pretty sure it was Don i emailed. The idle bypass the poppet from the rear of barrel valve, yes it's at 10psi. You mention to keep the idle lean but doesn't that hurt throttle responce, i thought it had to be fairly rich for the transition from idle to flat chat.
Suicidebomb, the -1/2 pump puts out about 4.7 GPM at 4,000 RPM's Zip. |
Thanks zip
Originally Posted by suicidebomb
Thanks zip
Zip. http://www.goodvibesracing.com/searc...fuel+pump+flow |
Thanks again zip.
| All times are GMT -8. The time now is 11:38 PM. |
