Originally Posted by gnsrule
I would think if you have 35-40 lbs in the pan, then your already blowing the oil off the skirts and you have bigger problems by now. I only run 35 lbs on the topside of the pistons and never measured whats in the pan. I would only hope its way less than boost.
snicker, snicker, snicker... This is getting interesting.....
OK let me try to make it better to understand. When your crankcase goes positive like with 35 to 40 psi of boost Your gravity drained turbo doesn't return oil to the pan as well. I never said I had 35-40 lbs in the pan . then what did you say ? |
Look,
Im not tryin to get into a "lets see whos doink" is bigger. Ive never heard of puttin in a oil restrictor to fix a leak in a turbo. Consider its spinnin in excess of 30,000 rpm, id want oil to the bearing in a major way. Big truck turbos run 25+lbs boost all day long, whats the diff ? If Garret said so then id like to see it. |
Look,
BTW this is the stock oil feed hole on my 88mm turbos so can you please send me a 1/2 inch drill bit .I want to make sure they have plenty of oil :P http://i211.photobucket.com/albums/b...e/100_0540.jpg
| All times are GMT -8. The time now is 09:54 PM. |
