-   -   Got to love the idiots of this world (https://www.racingjunk.com/forums/showthread.php?t=25726)
newjack42 09-17-2009 03:47 PM
wow never heard of that one before :shock: thanks for the idea DD
CamBirdRacing 09-18-2009 03:23 AM
Dang DD, you beat me to it.
If you have a pipe plug that won't come out, take your torch and heat up the center of the plug, let cool and it will come right out. don't heat up around it, just the plug.
TheRabbit 09-18-2009 09:56 AM
Heat the stud up with an oxy/accet torch to a glowing red, then touch a candle to it. The wax will wick into the threads. Let it cool completely to the touch and then twist it out. Magic.....
Never heard that before. Hope I don't need it anytime soon, but want forget it!
Scooterz 09-18-2009 12:13 PM
Double/D,
That's really cool. I did not know that....
oldandtired 09-21-2009 07:41 AM
Great ideas all around. The main thing is patience.
Dave
signsbyesa 09-21-2009 08:57 AM
dd's way works great and i have used another way and it may
sound dumb but it works great only if there is room on the stud,
put a nut down then a washer and then tighten with another nut
and work the first one off and it will titghten on the washer and
work off, also spray with wd40 and if you have a can of butane
spray it for a while to get it frozen and then work the nut against
the washer/nut and it worked for me, only if there is room,
good luck :wink:
