-   -   572 into a '64 Impala (https://www.racingjunk.com/forums/showthread.php?t=24634)
Paulthebrit1978 06-26-2009 03:52 AM
Thanks guys thats awesome advice i am getting right on it and sourcing the parts
:D
zipper06 06-26-2009 08:56 AM
I don't know if the upper control arms on the rearend are the same setup as a 1965 Impala, but if they are you will need to add a heavy plate on the inside of the floor pan. Many years ago i had a friend with a mild b/blk and it kept tearing the mounts loose right out of the floor pan, we wound up having to weld in a 1/4" thick plate all the way across the mounting area.
