-   -   water coming out of head between header and head ??? (https://www.racingjunk.com/forums/showthread.php?t=24633)
gpracer 06-17-2009 12:38 PM
we are using arp head bolts no studs and we used sealer on all the bolts thanks
dparker 06-17-2009 04:50 PM
Re: water coming out of head between header and head ???
Originally Posted by gpracer
please help we have brand new motor and we got it fired up and we have water coming out between header and head on # 4 and 6 cylinder what is causing this we took it apart had everything checked and put back together and same thing happened again ???? what is causing this ty for any help
Do you mean under the header between the head and block or from the header flange? Not sure I am getting the picture of where exactly it is coming from. Are you using head studs?
Curtis
Where exactly is the water coming out from?
gpracer 06-17-2009 06:27 PM
we found the problem cracked cylinder wall taking back to machine shop thanks for all your help
curtisreed 06-17-2009 06:31 PM
Glad you posted back and let us know what you found. Sorry you had the problem.
Curtis
MEMRACING62 06-17-2009 06:47 PM
WHAT A ROTTEN ENDING :cry:
CamBirdRacing 06-18-2009 03:14 AM
Had that happen to a family member. Machine shop sleeved it and once he tightened the head down it cracked again. But his was getting water in the oil.
dparker 06-18-2009 06:37 PM
Gpracer, in using that 400 block your problem maybe the same again shortly. The 400 block is notorious for cracking the cylinders. The cylinders are simese and kinda thin. My advice if your running very much compression would be to invest in a dart block. Problem solved no more worries. Just a thought.
