-   -   what stall to run???????? (https://www.racingjunk.com/forums/showthread.php?t=24156)
txhunter69 05-07-2009 08:49 AM
haha nope onedragracer got that out of the way for me
dparker 05-07-2009 01:27 PM
Re: what stall to run????????
Originally Posted by onedragracer
Originally Posted by bowhay
i have a 383 with about 425+ horsepower
11.1 to 1 comp 489-491 lift cam
and 3.73s
what stall torque converter would work best :?: :?:
Where are you coming up with 425 + HP :?:
I think you have the 4 and 2 backwards, "245" sounds more like it :D
If we don't have accurate numbers we are wasting our time trying to help you. Take it to the track on the next race get some realistic numbers and we will be able to help you with your combinations. If your motor is putting out 425hp it should run in the 12's if its putting out 245hp you'll be lucky to be in the 14's. There's alot of difference in what you need to run, between the those two numbers.
bowhay 05-07-2009 03:41 PM
yea see thats what im talkin about
and thats why im gonna go and run at the next race
but i just wanted to see if anyone could give suggestions off of the info i had to give
i mean i am pretty green at the hole drag racing thing, this is my first motor to build
all i want is help
so any suggestions are greatly appreciated
but that is what i need, help and suggestions from people more experienced than me
and now i know that yall need more info so heres some more
duration at .50in lift is 219 int. and 227 exh.
lift is 489 491
vortec heads
flat tops 11.1 to 1 comp
th 350 trans
dual plane air gap
750 holley
hope thats enough
onedragracer 05-07-2009 06:21 PM
Next race Penwell Raceway May 23, gates open at 10:00, this will eliminate all the bullshit. My slightly experienced guess will be 15.20 @ 88MPH. :D
bowhay 05-07-2009 06:28 PM
alright
wel see
chevynovaman 05-07-2009 06:32 PM
IF YOUR GOING TO RUN IT ON THE STREET I WOULD GO WITH A 10 1/2" WITH 3000 STALL... OR POSSIBLY A 3500 STALL IF YOU HAVE A SMALLER OR LIGHT CHASSIS..
justin45 05-17-2009 07:17 PM
lift is 489 491
vortec heads
th 350 trans
dual plane air gap
750 holley
hope thats enough
its 1983 longbed single cab to.
but put around a 3200 stall on it bowhay
supergass 06-04-2009 01:55 PM
What a freaken punk you are onedragracer, what does 425hp have to do with ET in a 4800lbs truck anyway? It is totally possible to make 425 hp with a 383 sbc, and be a mild motor. I had the same situation happen to me when a punk claimed that a 406 (pump gas flat tappet) I built would never run inthe 6sec range in the 1/8th. He and his little boys showed up to see it run because I claimed it should run solid in the 6 sec. Well the first few runs it didnt and they all carried on and laughed. I found a small problem with number seven rocker and repaired it (it backed off adjustment) and it proceded to run a 6:76. They were all gone before I got back to the trailer! They thought they knew everything to! I figure they saved themselves a thrashing from me. I guess the moral of the story is keep your flap shut and you may learn something! Well if your pride lets you anyway.
onedragracer 06-04-2009 02:11 PM
I don't no who's flap your talking about assholy, but when You don't know what or who your talking about keep your assholy flap shut. If you want a thrashing be a penwell raceway in odessa tx june 20, 2009 I will show you what a thrashing and a asswhooping is all about.
onedragracer 06-04-2009 02:14 PM
By the way assholy, why don't you try running in 6500' DA then you can run your mouth. Living in Georgia, like you do, the mountains up north aren't that high.
By the way assholy I'm from Reynolds Georgia, tell me where you live assholy.
