-   -   Removing block filler from heads (https://www.racingjunk.com/forums/showthread.php?t=24076)
dak697 05-01-2009 10:05 AM
I am sorry to say but you cannot get it out
tcarda 05-01-2009 01:53 PM
I kinda figured he was screwed, but I thought I would at least ask to see if anyone knew of a way. Thanks everyone!
oldandtired 05-01-2009 04:44 PM
If anybody does that to RJ members in NW Georgia, PM me. I will do a noharm/nofowl visit as my work allows.
My obversation and tools taken to the site may not be perfect, but I may be smart enough to help.
Dave
BEAST477 05-01-2009 04:54 PM
Hey tcarda could you give us the add number or the user name of the person your buddy bought the heads from so someone else doesn't get burned by this person? I'll put them on the "List"
THERATTLER 05-01-2009 05:14 PM
the only reason they would be filled is if they were cracked all to hell , so you are screwed either way , :(
MEMRACING62 05-01-2009 07:37 PM
YOU NEED TO PUT THIS ON USER FEEDBACK AND SCAMMER WATCH , DRAG THIS GUY THROUGH THE $HITT AND SEE IF YOU CAN GET YOUR MONEY BACK OR ATLEAST WARN OTHER RJ USERS ABOUT WHAT A POS THIS GUY IS !! :evil: :evil: :evil:
tcarda 05-01-2009 07:40 PM
OK, I will ask him for the username or the ad number. I guess I didn't know about the list. The only thing that I know right now is that they came from N.C.
obsessedtruck 05-01-2009 09:02 PM
YUP HE IS S.O.L. !!!, When I filled my block to the bottom of water pump holes I oopsed. The head bolt holes are bilnd on my merlin II block. Closed off one side of the block. I used Muratic acid in it and got a small portion out. But in the I ended up cross drilling water ports into it and drilling trough the back of the block to go around the rear cyl. Worked like a charm using 9/16 concrete bits. But in the heads his s.o.l.
