If you plan on running 8000 rpms, don't skemp on the block. The block, crank, and rods are what decide how long your engine will last. Especially at 8000rpm. Get a Dart block and go to the next step.
Re: HIGH RPM 540
Originally Posted by ultimatewarrior1
THE THING IS I HAVE A GM 502 BLOCK NOT A AFTER MARKET BLOCK .I THOUGHT I WOULD NEED A AFTER MARKET BLOCK TO GET 572ci ISN'T THE LIMIT ON THE GM BLOCK 555-565 I'M NOT DEAD SET ON 540
Which GM 502 is it, a Bowtie ? Like Parker mentioned a motor that spins that high will need very good parts to stay alive. Titanium valves would also be on that list. |
Re: HIGH RPM 540
THANKS FOR INPUT JUST TRYING TO FIGURE OUT WHICH WAY TO GO I SEEN IN THE CLASSIFED SECTION SOMEBODY HAD SOME BEAST HEADS FOR SALE PORTED BY REHERMORRISON WITH SHAFT ROCKERS .JUST WONDERING IF THOSE WOULD GET ME IN THE POWER RANGE I'M LOOKING FOR.
HIGH RPM 540
WELL IT COMES TO BIG CHIEF HEADS OR VICTOR HEADS. FIXING TO PUT A FRESH VAVLE JOB ON MY AFR 335 SO I CAN SELL THEM. TRYING TO GET THE NEW HEADS FIRST BEFORE ORDRING THE BOTTOMEND SO EVERTHING MATCHES UP.I APPRECIATE EVERYBODYS INPUT ON THIS SUBJECT .
Will be more cost going the 18 degree setup for sure, if it were me I'd order Brodix bb3x's for it.
I just finished chassis dynoieng my truck today. I ened up with 740 at the wheel. With my drive line that comes to 1070hp at the crank out of my little 522. Peak hp @ 7200rpm. Thats with RFDs 1803 Oval port Brodix big dukes. Im not done yet either theres more in it yet.
HIGH RPM 540
THAT LOOKS LIKE A GOOD DEAL BUT WHY GO WITH OVAL PORTS?THIS DEAL WOULD HELP THEY ARE 200 MILES AWAY.
Oval ports are the way to go now you'd make the power you wanted with them heads for sure, and can put good valve in them.
brodix ovals
just how good are the new brodix oval port -3 extra heads compared to the conventional rect port heads of the same port volumn. Anyone have any experience with them?
| All times are GMT -8. The time now is 01:06 PM. |
