i use to have a 302 sbc, aluminum rodded, solid roller cam and some raised exhaust dart pro1's. That thing would zing up there and still it never broke or had any problems.
Ya I going to scrap the 331 idea. I just remember how it use to wind up effortlessly. He had it in a very cool looking 68 Camaro and it use to hike up the drives tire and halled ass.
Kwkracing,anymore details on the 302? |
The 302 foundation sounds like the way to go... being the original blue print is only about 1000RPM shy anyways... all I know is that that Nova Video you posted was very cool as he shifted into 2nd & popped up the front wheels again!! You gotta love the sound of a SBC @10000!! makes we want to loose the BBC sometimes....
Originally Posted by zipper06
Hey Mark,
There's a couple good deals on SB2.2 heads on ebay right now, i set clean with TIT valves and PSI springs never damaged for $2000.00 and another set of Joe Gibbs brand new (no valeves or springs) for $2300.00, both are good deals. JMO Zip. |
Mmm....found this on Racingjunk. A good price with the trans set-up.
http://www.racingjunk.com/post/13085...uns-10.02.html I phoned about it but it has a stock GM block. Not sure about a stock block and that high of rpm? |
When it comes to valve train dont go the cheap route, spend the $$$ for good parts. Also on a piston wrist pin do not be talked into lightweight, heavy does not flex and with the high RPM you need stregnth. I had a 377 that I shifted at 9500.
http://www.youtube.com/watch?v=-D4uVZnw4M0
here ya go , nice high rpm engine , wonder what the valves,and rings look like the pipes are glowing near melting point |
what about trying to square the block and balance it? it should last,and pump some ponies :?:
speaking of Indy cars. do you remember when they tried to run them at Texas Motor speedway a fews years ago and they had to cancel the race because the Indy car Drivers were Blacking out due to excessive "g's" going into the turns....
Ya Gotta respect that Danica Kirkpatrick..shes got the touch. |
| All times are GMT -8. The time now is 05:10 AM. |
