-   -   trans-brake (https://www.racingjunk.com/forums/showthread.php?t=21983)
macksstreetrod 10-08-2008 07:30 AM
Hey guys...thanks for the help
pulled the sol seams to be fine, pulled the shaft out, there is a spring in the end of it and has an adj screw on the other...with the sol where it was their was no tension at all. seams to me when sol is screw in ageist the shaft and spring it should push sol out then when you press button it goes in....i adj.to where sol plunger is pushed out but still has a little bit of travel before it hits the shaft..going to try that and see .....thanks for replying
Dale
hammertime 10-08-2008 07:44 AM
Dale
Are you sure it has the right length tbrake sol on it ? They do make different ones.
kwkracing 10-08-2008 12:28 PM
can you tell us about the tranny? did you just put it together? Did you buy it used? who put it together? This is a simple problem but we need a solid place to tell you to start looking. Depending on the year of the case............................ you probably have reverse flowing in the wrong hole were the early model rear pump was, making for no reverse when a transbrake vb is used, transbrakes all use the latemodel cases with reverse feed hole near the bottom not the top. When using a 62-64ish case you need to plug the origonal hole and drill it in the latemodel spot. I could fax you pic if needed.
Keith
macksstreetrod 10-08-2008 01:27 PM
got it used from someone you cant trust ,no sense in even asking them...I pulled the sol out shaft is in...has spring on one end and an adjustment screw on the other ...I measured all together and there is no way it was pushing the shaft when u hit the sol ..so i backed of on the adj. screw to where there is about 40-50 tho.space between sol & shaft..now when I hit the button it pushes shaft in ...
goes in revere now when i press brake seems to be no strain in rev. but not sure of clearance should have between sol & shaft?
try to give it a try to night
Dale
cepx111 10-10-2008 12:39 AM
That black cat scares me....
kwkracing 10-10-2008 02:15 PM
i think thats a dog
macksstreetrod 10-11-2008 10:14 PM
My ex-wife thinks were both dogs :roll: ..thanks again guys...thanks a bunch for the help
Dale
nova7415 11-27-2008 09:42 PM
cat?
It looks more like a dog to me :shock: .
