Alcohol
As long as it is sealed tightly, it should last indefinitely. As stated above, keep the drum off the concrete or ground to minimize corrosion of the container. Good luck with the alky.
Hey Chris,
We started using Klotz top end lube and we really like it alot. We actually picked up some et using it over whatever they were putting in when we bought our fuel with the lube already in it. David is right it will keep just fine. Curtis |
Hey Chris,
We started using Klotz top end lube and we really like it alot. We actually picked up some et using it over whatever they were putting in when we bought our fuel with the lube already in it. David is right it will keep just fine. Curtis Chris |
Klotz
Don't worry as fast as you burn alcohol it wont last long. Usually when someone gets a new alcohol engine theyll burn a drum just tuning their car in the shop.
If you'll install a 3/8 fitting on the plenum of your intake and run a hose back to the cab of your car with a gas ball valve on your end. You can heat up your engine in about 1/3 the time. When you open the valve it will give you a vacuum leak that will lean your engine. It will heat up aleast 3 times faster. Which means you use 3 times less fuel. |
Hey Chris,
Re: Klotz
Originally Posted by fla1976
Chris |
I have another question. Since my car runs on alcohol, could I run E-85 in it? Again sorry for all the questions but first time with an alcohol setup.
Chris |
Chris Curtis |
Chris Curtis I see now, I have a lot to learn.............. :? :? Chris |
| All times are GMT -8. The time now is 11:07 PM. |
