-   -   flashing around spark plug boot (https://www.racingjunk.com/forums/showthread.php?t=21502)
hkfs72 08-04-2008 03:18 PM
I called MSD today and they said it was normal. I borrowed some moroso 40 wires and still the same. Changed from autolites to ngk and cleaned up grounds on both heads , block and frame new rotor and cap and still the same. I'm not going to pull my hair out , but just trying to figure out what is causing this. BTW the plugs are gapped at 35. Thanks for the replies.
olds48 08-05-2008 03:14 PM
If it's flashing it's leaking,bud.need to figure out how to keep that energy from escaping.You want that electricity arcing in your cylinders,not under your hood :D
