-   -   Need help on BBC alcohol tune.ROOKIES (https://www.racingjunk.com/forums/showthread.php?t=20875)
hammertime 06-08-2008 02:36 PM
You realize that the leak down is just a base, and that you'll have to change it 2-3 times every day, right?
Start the motor, loosen the screws, fatten it up until it surges, then lean it back out just until the surging stops.
As for plumbing.... See below.
http://i204.photobucket.com/albums/b...c/IMG_0762.jpg
I've got to ask why change it 2-3 times a day ??
Once you get it set the only change you should make all year is a pill change from hot to cold or cold to hot weather ??
I run return straight to top of fuel cell, crank trigger MSD.
OneBadGMC 06-08-2008 05:03 PM
Barrel valve leak changes with the weather, just like the main pill does.
I take it you don't own a weather station.
hammertime 06-08-2008 05:43 PM
I do .. mine stuff doesnt get changed at all, all year. Toilet or Terminator must be I am just lucky. I know NO one who changes the BV once they get it set where the car likes it. I dont even change the pill in my setup its good either way. Spring Weather to Hot Summer weather no change 7.55 in spring 7.55 in hot guess I got lucky. :D
OneBadGMC 06-08-2008 06:10 PM
Rather be lucky than good anyday.
hammertime 06-08-2008 06:13 PM
ahmen to that :lol:
us7race 06-09-2008 02:15 AM
What do you know on a High Speed Lean-out? :wink:
OneBadGMC 06-09-2008 07:43 AM
I know if you don't set it right, you can plan on buying new pistons. :wink:
Do you have a more specific question?
us7race 06-09-2008 07:21 PM
My buddy has just added one and I figured I'd ask. He is going to start out with the smallest pill and go from there. His EGT's on a couple of cylinders were down to around 300 still ran 6.52 @209 in the 1/4.
I think it was a 4.19 in the 1/8 on a not the greatest track..his 60' was off from .980's to 1.0's. so Hopefully with more seat-time in the car and the high speed lean-out can go 6.40's or better..
OneBadGMC 06-09-2008 09:44 PM
Try this site: http://dragracemath.jimhatleyracing.com/fuelsys.html
Should help him setup the high speed if he knows what he's looking at. :D
OneBadGMC 06-11-2008 08:32 AM
Just because I thought of it... Aren't you running a normally aspirated motor?
