Originally Posted by signsbyesa
your compression should be perfect but how big is your cam?
you would need a HUGE lift ont he cam to get in the 9's but with spray you might go faster, john cunningham ran a nove on the pump gas drags, he had a bbc with 13:1 comp and a .850 lift cam and he was the fastest on gas he ran 9:91, only motor, you can see his car on a web site that did his front end 8) www.smithracecraft.com Wow talking about pushing the limits. JMO Cp |
yea cpex, when you ask these guys if they drive it on the street they
say "I drive it all over never have heating or any other problems" so I don't ask anymore, but too much lift for me. By the way, that nova that john cunningham built sold on this site for 45k and the motor has not been hurt, with spray it runs in high 9's, nice car, mini tubbed :wink: aslo note that on the pump gas drags, they have to drive their cars to each state and drag strip in the car they brought, no trailers 8) |
I will answer your question with a question! Why? If you start running 9's you are going to spend big bucks that you don't have to spend running 10's! Examples: Firesuit, engine diaper, parachute, licensing and medical exam just to name a few! My 1971 RS Camaro is certified but I have no intentions of running it in the 9's with a small block. It has ran 10.03 at 133 and that is just fine! Maybe you don't race were the temperature gets up to 110 degrees on race nights but when it does racing is not fun! :?: :roll: 8)
in my opinion the fire suit and engine diaper (cheaper one) is a not a bad idea for any class or test and tune guy to have and wear..
fire and skin don't mix and oil and tires don't go well either. :idea: |
fire and skin don't mix and oil and tires don't go well either. :idea: suicidebomb |
fire and skin don't mix and oil and tires don't go well either. :idea: suicidebomb But in reality it's easy to run in the 9's with a rat motor at 3300 lbs. i just put together a 477" no nitrous, 1050 dom. on gas in a 3700lb car it went 10.44 3rd. pass and 10.40 on the 5th pass down the track, but with a much smaller cam .722 lift. JMO Zip. |
how good is Howards cams and racing components
nos is cheap power and can cost you parts. better to build horsepower on the motor. its much cheaper in the long run.
| All times are GMT -8. The time now is 07:25 AM. |
