-   -   water in engine (https://www.racingjunk.com/forums/showthread.php?t=20074)
zano 03-06-2008 01:00 PM
good idea i'll catch it in 1 of the aeroquip fitting packs although 1 drop in 9 minutes isn't much i'll see how it is tomorrow thanks zano
dgordner 03-06-2008 03:11 PM
water in oil
I built a big block this summer that had the same problem. Dis you use a water sealant on the head bolts? They go right into the water when you bolt them in. I pulled all my bolts and used a thread sealer and the problem stopped.
zano 03-07-2008 05:45 AM
no seperation i think it's all oil talked to a builder last night he said run water only at first , antifreeze will lock up the bearings way quicker than water does anyone know if this is true or not ? thanks zano
