I would price it for $4,500...when they start with the doubting..then tell them ok....since you do not believe me..i will knock off $600 and you can pick it up for $3,900...if it doesn't run what i say it does..i will knock off another $300......you still clear $3600
Read my signature really close. " There is more then one way to skin a moving cat" start going with the flow instead of pulling against ..its a much smoother ride ! Brian |
I like the way bjuice think,s. :D
My 496 is 11:1 with Canfields and a 660 lift solid roller.Fighting wieght is 3365 with driver.4800 stall and 28" tires with 4.88 gears.I was runing 6.90s leaving veeeeery easy(1.65-70 60').You making me look bad! :D Don't matter what other people think,sometimes you you can just build a "ringer"
I had similar set up in my 73 nova except mine was bored over .060.
305 magnum hydralic cam, 750 double pumper, team g, flat tops. Ran 7.00's w/ 1.54 short times all day long I knew there was more there but I was short shifting @ 5200 rpm to make the motor last, 3 speed T400, 488 rear cogs, and 9 inch 4500 converter. Sounds like you have a 2 speed with that much gear. Whats the ad number? Might be interested. Hook a brother up... ><Cp |
1110068 is the ad #, I may put this thing back in the car and take it to the track, may sell better if people can hear it run and see it run those #'s
Originally Posted by Tod74
Originally Posted by SPEEDNEEDS1
The heads have been ported and have 2.25-1.88 valves. It has a 5.57 gear and a 4000 stall converter shifting at 6200. It is a basic good street engine and I ran it 12 passes and it went 7.09 first pass foot break and 6.95 2nd pass leaving at 3200. I pulled the 2 step chip out and left on the converter and it went 6.93 4 passes in a row!!!!!!!
It has a 5.57 gear
rpm was 6400 at the finish line, but I have a 10.5x33W witch is a tall tire.
| All times are GMT -8. The time now is 01:01 PM. |
