-   -   BBC stock heads (https://www.racingjunk.com/forums/showthread.php?t=18606)
badrad 10-13-2007 10:08 AM
The roller I'm using has 10* more over lap so should idle just a tad tougher but run like a raped ape. I wish I had researched this before buying $3500 in parts I don't need now! Looking for 11.50s on the motor as cheap as possible while slowly building a 496 beast.
badrad 10-16-2007 09:26 PM
My pistons are pretty much flat tops with .14" domes and zero deck height, since I have bigger than stock valves will pistons/valve clearance be a huge problem with a .616 lift cam?
