-   -   Somebody Settle This for once (https://www.racingjunk.com/forums/showthread.php?t=18397)
blaserman 09-17-2007 07:52 PM
rolller
Thanks for the tips
pipes434sbc 09-19-2007 03:35 PM
I run what comp cams refers to as "street solid roller"in a 434sbc with ported 230cc heads.Works awsome.600 & change lift on a 108, yet not quite so aggressive of a ramp,allows a tighter lash(.018)& less spring press.Adjust valves at beginning of summer,& at end,thats it.Last time only had to set a few,course I do have stud girdles,helps.Well worth running mechanical,pumps anything hydraulic I could put in that motor,throttle response is nothing short of unbeleivable,gobs of power & sounds super cool.
rpmengine 09-20-2007 01:31 PM
dist. gear
Most mech. roller camshafts require the use of a bronze dist. gear. This is a maint. item. I change mine once a year.
jbsjunk 09-20-2007 04:13 PM
Re: dist. gear
Or spend some coin and get the composite gear from Comp Cams.
pipes434sbc 09-20-2007 06:54 PM
thats what i run
