-   -   Will a 10 bolt chevy hold 550 hp? (https://www.racingjunk.com/forums/showthread.php?t=17653)
PartyTimeRacing 10-24-2007 04:20 PM
Sure it'll hold up, just don't put a sticky tire on it.
It's not the horsepower, it's the torque combined with the weight of the car and its ability to hook the tires.
jnnance 02-01-2008 07:37 AM
10 bolt rearend
a 10 bolt rearend is as strong as a 12 bolt [ stock ] the ring gear bolts on a 10 bolt are bigger then the 12 bolts, the weak link in a stock 10 bolt are the axles , a good spool and a set of good axles and you will be fine. also a 10 bolt rearend is FASTER THAN ANY OTHER REAREND, by the way the pinion runs on the ring gear.
capizzoracing79 02-06-2008 01:07 PM
10 Bolt
If you use quality parts you won't have any problems,ran 10 bolts for years.
